i have a 1966 dodge dart, 3-speed on the column with a 170 slant six, when i purchased it, i planned to drive it to school and back, which is twice a week, and to church on sundays. and then to rebuild the engine in september when my financial aid comes in for the fall semester, however, i believe i have a blown head gasket as of today, i have not look at it good yet, as i have a test i have to study for. but out of nowere it wouldnt gain any speed, no matter the gear (well, it would, but very slowly) and when i stopped the car at the light, it shut off, wouldnt restart until i let it cool for 15 minutes or so, then i drove it just to the nearest store, shut it off, popped the hood, and i had some white smoke coming from the top of the valve cover where you put in the oil, and from the overflow hose at the top of the radiator, i check the oil and it was so thin it was just dripping of the dipstick, so im assuming there is water in the oil, as it had a recent oil change using 20w50 and a quart of lucas. so it should not have been that thin, unless thinned by water (yes i understand the two dont mix, technically)
long story short..... i would like to get an engine to put in the dart until i can rebuild the original in september. im on a tight budget, and found a couple 225's for sale one is from a 73 dart, is already pulled so i cant see/hear it run, the other is from a piece of equipment, the year is unknown but seems to be frmo the 70's, looks to be in great shape, and i can see it run as its still in the equipment.. when the time comes and i put the original back in, i will most liklely resell the 225, unless i truly fall in love with it....
question here is, with this engine go right in? or do i need another k-member and or other parts? will it bolt to my trans? i cant seem to find any 170's locally. and i need this all to happen pretty much as soon as i possibly can.
thanks for any help and input
