Woods74
Broke Senior
I've got the 360 pan, although SB are probably all the same.
Thanks!
Thanks!
Here is one I just finished.
But Lemmie ask.......why not just run a windage tray? Will that not do the same thing?
Won't the baffle keep the oil lower in the pan vs just keeping it off the crank? Less slosh.
The stock oil pan isn't very deep; when launching with slicks the oil runs toward the back of the pan and can uncover the pickup
Actually those seams are supposed to be sealed for it to work right I used the grey oil-resistant RTV... won't see how it holds up until next time I have to drop the pan though". I disagree with this. Notice in the picture of the stock baffle that there are openings at the end of the baffle. Homemade baffle in the first pic also has these. This is to help oil return to the sump.
Yeah guess you're right but mine had a pretty big space on the back compared to the ones in this thread if i hadn't sealed it the oil would've just slipped past
Just my 2 cents, but I think I'd rather have some miniscule gap around the baffle, like was shown, than have some RTV smeared in the gap, just HOPING it doesn't come free and get sucked up into the oil system passages. Regardless, I applaud your effort.
hahaha, I didn't notice the date. I didn't think I brought it back, maybe I clicked into an old link, and didn't recognize it.Funny thing you brought back this thread I still have that same pan with the same baffle and same smeared gray RTV on the back seam... I was honestly expecting the RTV to start coming loose at some point but it's stuck on there just as well as the day I put it on back in 2011 or whatever. I wouldn't do it again but it's stuck on there so tight it would be a chore to remove lol
BTW I had that pan on a 360 that I put about 25k miles on so it was submerged in oil for a long time...
I tend to do that when I search, I find an old thread with the info I need and after reading through it a while I make a post like it's a current thread haha
I did the same thing when I first posted here and got beat up on it LOL
