Man, are you sure that you’re not my neighbor ? He has it all figured out too. Knows absolutely everything, pertaining to absolutely everything. All based on theories, assumptions and as much **** as he can possibly pull out of his *** pertaining to everything. He’s a genius, knows absolutely everything. Ah ha !!!
nah, im over 400 miles North West of Pittsburgh
did i ever tell you the story about the time i lost brakes around there?
we had a VW passat at the time, and the wife had to go to philly for something
it was just me and her at the time, so we decided to make a road trip out of it
i wanted to make sure the car was OK before we left so i put fresh oil in it, and new brake pads all the way around
all went well but on our way back home, just outside of Pittsburgh, i lost all brake pressure, i mean, pedal went through the floor
i tried the hand brake, and nothing
pumped it a few times and nothing
so i pull over and get under there, expecting to see brake fluid gushing, but all was clean and not a sign of trouble
want much i could do, so i started driving again, real careful and after about a mile or so, the pressure came back and all was it should
drove the entire 400 miles home without a hiccup
of course, as soon as i got it home i put her up on blocks took a closer look
it turned out the driver side rear caliper bolts had worked their way out and were gone
the caliper had lost its pads and somehow managed to get hung up on the bracket, with the piston actually pushing up on the bracket, which musta been what caused the pressure to return
its one of those, if i hadnt seen it i wouldnt have believed it moments
