Does anyone need an 85 360, trans, and transfer case
krazykuda
How-To Section Editor
Orland Park, IL
Hi guys. I got a line on a 360 engine, trans, and transfer case out of a 85 Ramcharger.
I have too many engines in my stash and do not have room for this one. The seller claims that it ran good when it was pulled, it has over 100 k miles on it (I think closer to 170 k), so I would recommend considering it as a core and needing a rebuild.
It is from the pulleys to the transfer case, including exhaust manifolds, and oil pan to carb. Someone put an Edelbrock carb and spacer on it (I think has the square bore intake and adapter for the square bore car). The trans is a 727. It is currently sitting in the back of a stripped pick up truck outside. The alternator also looks pretty new.
It is out of an 85 Ramcharger. Located in Joliet, IL.
If anybody is interested in it, it's cheap - $200, but you have to come get it with a pick up truck. Let me know and I can get you in touch with my friend who knows the seller.
