Does The Six Pak Fit Under A Factory Hood?
kend
GA
Will a factory 340 Six Pak setup fit under a stock '73 Duster hood?
Excellent question!
A old member (John - RIP)
He put one under a 67-8-9 Cuda hood, no problems.
Excellent question!
My 73 hood does allow for the 6pk with stock manifold. Any high rise, I would say no. My stock hood is raised slightly in the center to allow for the air cleaner clearance.
My brother just installed one on his 1973 Duster a month ago. It fits great, only issue is you need a 3 speed/ variable speed wiper motor to clear the air breather. If you run an automatic you also have to modify the kick down linkage. Bobby
