Why not post a picture or two so we know what you are talking about and what they came off of. If you drop an ad that doesn't follow the rules I will usually give you a break and a chance to correct it. If you drop an ad and walk away, the ad get's removed. That's where we are headed.One set of Dog Bones. If you need them or the spider send me a PM. I don't need them and they are going to get tossed.
Shipping is on your dime.
Thanks for mentioning the issue with my post. I'll gladly post a picture, and the block was an early roller la. Cracked between the center upper head bolt boss like most.Why not post a picture or two so we know what you are talking about and what they came off of. If you drop an ad that doesn't follow the rules I will usually give you a break and a chance to correct it. If you drop an ad and walk away, the ad get's removed. That's where we are headed.
Sorry if I was a little gruff. I got overloaded at a bad time when I had a hundred things going at once. I'll send you a pM. I stripped a roller 318 year ago and threw those pieces away. I could use them. Thanks.Thanks for mentioning the issue with my post. I'll gladly post a picture, and the block was an early roller la. Cracked between the center upper head bolt boss like most.
Spider is in the top photo, Dog Bones in the lower photo.
Thanks for the kind words, Mike.
I’ll get back to you this afternoonSorry if I was a little gruff. I got overloaded at a bad time when I had a hundred things going at once. I'll send you a pM. I stripped a roller 318 year ago and threw those pieces away. I could use them. Thanks.
Thanks. I sent you a PMI’ll get back to you this afternoon
