68 HEMI GTS
as i've mentioned before im going back to the stick shift. i've had two proshifted 4 speeds i bought back when i was still a teenager and never used till 2 years ago. one is a stock ratio and the other has custom low gearing. well after running both in the dart, i discovered the low gear trans was wore out and needed a fresh pro shift (i couldn't even keep it in gear). i ran the stock ratio trans for about a week but broke it at the track, it was also in very used condition. last year i had the gearset redone for the stock ration trans but never built it. after talking to the clutch guy i realized i need a low first gear, so i just had the other gearset redone. figured i might as well build both of them while i was at it. a lot of people keep asking me what they look like so i figured i'd post some pics.
i had second re-proshifted on both gearsets and had 3rd & 4th faceplated, Libertys is suppose to be working on a faceplate for second.
faceplated 4th
faceplated 3rd
faceplated slider
proshifted 2nd
proshifted slider
both traneys
main shaft assembly
assembled
low gear input
low gear cluster
faceplated 4th
faceplated 3rd
faceplated slider
proshifted 2nd
proshifted slider
both traneys
main shaft assembly
assembled
low gear input
low gear cluster
