sydcuda
I have an 8 3/4, 489 carrier, out of a Dodge Phoenix here in Australia (ie. in USA basically a 4 door Plymouth Fury). The set-up is of course way too long for my 68 cuda so I am having the housing shortened to A Body length. The existing axles I have with the 8 3/4 measure approx. 30 3/4" from the axle flange to the tip of the splined end. The axle has a tapered area just after the splines finish, and then thickens again to the same diameter as the splined area. The length of the axle from the point immediately after the taper (in the pic, where the tape measure is pointed to) to the axle flange is approx. 27 3/4".
As far as I can tell from the Moparts site, axle tech section(http://www.moparts.org/Tech/Archive/axle/16.html) the axles I have equate to 70-71 C Body length (stated there as 30 5/8") or 71-74 B Body (same).
I am wondering whether this axle would be a suitable donor to have shortened and re-splined to A body specs. According to the Moparts site 67-72 A body axles measure 27 11/16". I have about that much length in my axle excluding the tapered area.
Has anyone gone this route with a similar axle?
