Door handle spring replacement
ARuiz28
Active Member
Camby, Indiana
Anyone have experience replacing these? Its a 63 dart but i believe 63-65 are the same. I can’t pull it out, because the window regulator is in the way. Does anyone know which bolts I need to undo to give me the clearance?
Can't you just unbolt the window regulator if it's in the way of removing the door release pivot? I don't recall ever having a problem getting one out.
