Door hinge interchange? Darts, mainly
Front doors any A-body 67-76 left and right the same.
NO NO NO they are not all the same. 73 is 1 year only 74 to 76 is different yet with an entirely different window regulator. Door glass follows the same pattern 73 1 year only Etc. I know they appear the same but unless you've done it you wouldn't know
Just to clear things up. All 67-76 A-body front hinges, whether 2 door or four door and 67-70 B-body front hinges will interchange. There is only one hinge made.
It is flipped over when installed on the other side.
And only the direction of the pivot pin indicates which side it was installed on.
But the pin can be removed and installed the other direction if you are concerned with that.
Top of the pin indicates the top of the hinge when installed.
And there are pickups and vans with lower hinges that will also work. Sometimes they require modification of the top hole in the body side of the hinge.
I have retired from rebuilding any more hinges but am happy to answer any questions that members have.
Just email me at
moparleo@hotmail.com
Hinges is what was asked about
