Door Panel Installation Help
Ricks70Duster340
My "Blue Bondo Baby"!
Sisterdale, TX
Bought some replacement door panels for my 70 Duster. Thought the exchange would be really easy. That is what I get for thinking. The panels have cutouts, which I cut out for the clips. What is the secret to getting the clips lined up with the holes in the door? Once the clips are inserted into the panel, it is not easy to move them around. I can get a couple of clips lined up, but then the others are off. I am a pretty patient guy, but....
I had to glue my clips in since the Masonite was old and damaged which limited play but I still got them in. First, figure out which holes in the door you will use (there are extra). I used a flashlight to see the final insertion.
That's exactly what I did. They (Legendary) give you a small knife blade to make slots for the clips. I like the velcro, just try to get as "thin" as possible.
I may do that. I cut out the slots for the clips, but having a time trying to get everything lined up. Since this is a new panel, all the clips need to be oriented in such a way to line up with the holes in the door. Holding the panel with one hand while pushing up to keep it inserted into the top "rail" while doing this is really taxing.
What we did when we initially cut slots in our new panels was put a dab of grease or marker of some sort around the steel holes. Slid the panel into where it would be and then pressed around the perimeter. This left slight marks on the panel where I knew the clip would need to be. Eventually went to velcro. Did that for the carpet on part of the console too. Hope that makes sense.
.........I am a pretty patient guy, but....
If it's impossible it just takes longer!
Are you trying to clip the whole hardboard? I have Legendary panels. They say to separate the two layers with their supplied angle knife. Mine were a pain to separate, but I could reposition the clips as needed. It helps to have the old one for reference.
Mounted like this on the panel I could hardly move them . That clip on the right is a YO part. It would be a real ***** to pull back out of the hole once in ........
The tool is just a bent rod with a sharpened flat ya' dig 'em out and spread 'em with.............
They came out OK, but don't be in a hurry........
CONVERTIBLE_REAR_DOOR_PANEL_INSTALLATION_GUIDE.pdf (legendaryautointeriors.com)
