Door Panels and Air doors
Gizmo666
Member
Newfoundland
When did they change the door panels in the Darts? 1973 is a bigger panel?
Can I get aftermarket air doors the one on the passenger side is missing
AIR DOOR ?? You talking about the one for fresh air under the dash. I have a couple spares from 67 -8 cuda . I'll have to check if they're pass or driver side .
The doors changed in 73. They got rid of the quarter window and made the glass bigger to make up the difference. The window regulator is also different.
The door in 73 had a plastic upper trim piece and the earlier ones had painted metal that was actually part of the door. Im not sure if the actual door panel was a different size or not.
On the air door, its part of the air box on a 73 for the passenger side. I think the driver side bolts on to the cowl.
I think this fresh air-vent door is '67 to '69, does this look like it will work?
