Door panels
Any auto upholstery shop should have the material you need...at least that's where I get mine. It's a black-ish compressed cardboard that is water repellent and easy to cut to shape. It's similar to the OEM material, except for color.
Mine are from a plastic sheet of some sort....with the cage the arm rest pads would not fit....figured it might look a bit odd with oe style door panels. Not to mention the 4 of them only cost me 20 bucks or so....
I made mine out of aluminum and glued headliner material to them. I used plastic push pins to hold them in place.
Hi
I will be attempting this type of project too...
I figure I can use originals as a pattern...
Door handles hit roll cage...
I can probably recover the cost by selling the originals to someone that wants restored look instead of race look...
:burnout:
My duster came with some fabbed stainless ones. I'm going to try to make them work - just need to put something behind them to quiet them down~
