Passenger side door sticks. Closes easy enough, but if you are trying to open it from the outside you can't. From the inside you have to give it a little smack to get it loose. The driver's side is easy as can be, just click and pull open, no drama. I checked the location of the striker - everything looks the same one side to the other. Car has been this way since I bought it 28 years ago. Now it has a new striker, new latch, and etcetera. Even the sheet metal behind the striker is new. Still the same as before! Any ideas?
