rod7515
Working on my 66 Dart. I was going to just tape off the windows when its time to paint but I have decided I should pull the window, tracks and regulator so it can all be cleaned and it will make painting easier. So what has to be removed and what order does it come out of the door. Here are some pics of the door and the bolts holding everything in.
The nut on nut on the far right with the waffle type washer goes to the vent assembly and the 2 allen head bolts on the last pic is also part of the vent assembly. does this get removed before the window or wait until last.
Then 3 bolts aounr the window handle regulator ad which other bolts need to be removed for the window and regulator to come out. Also does the window come out by itself or as one big assembly including the regulator.
I will be removing the door latch as well. This will allow me to clean the inside of he door and spray a rust inhibitor into all the seam areas of the door.
Appreciate any help you can throw my way on this. Its not something I wanted to tackle but I guess its the right way!
Thanks Rod
Thanks Rod
