Door window replacement
Roadart
Escalon ca.
Got replacement glass for my door yesterday (from a great FABO member),do you have to remove the entire assembly(meaning the wing window section) to get the door glass in ? If not how is the rubber seal at the top front removed? I see a phillips head screw but it did not budge with normal strength.
What year?
what car?
My 67 dart had some black rtv like sealant between it and the outer door frame after it was cut / pulled away from the metal door skin the vent window frame came out easy.
There is a seal and plastic slides on the leading edge of the glass. If yours are in good shape reuse, the replacements work but are crappy.
I never remember to give year etc. It is a 72 dart. After fabo help and u-tube the whole assy. has to come out to replace glass.
