retractable
I was having problems with the right front door closing very hard. I had to slam it way too much. I have new door seals and even with the door in bright Sun to get the seal to set it was no better. I found the door seal binding on the latch side. When I looked more found the pinch weld was too long and the seal stuck put too far. I cut 1/8 to 1/4in off the pinch weld to make the seal fit better. The door shuts much better.
