WildCat
Seen in another thread about using DOT 5
I built my Dart and the system was all new, had a quart of dot 5 that I thought I would use in my Prowler, but after reading that you needed to completely clean & flush the system decided against it. So the Dart was 100% all new system so I used it in the dart.
A few years later my SSBC front calibers started to leak, luckily for me I was able to get the car home safely, get the calibers rebuilt (SSBC DID IT FOR FREE)
Flushed the system and put DOT 4 in it. So far so good.
Use DOT 5 only if the system is compatible with the fluid
I will NEVER use it or other fluid again if not recommend for application.
My convertible top pump has red auto trans fluid, like it came from the factory.
