Double flare offset?
NoahSewal
Sioux City IA
I was flaring my lines in a couple weeks ago and one of my double flares came out kind of wonky. when i went in to roll the end of the line it seems like maybe more material went to one side. but when i flared it out it seems like everything is good on the inside as of symmetry, the lip just seems to have more material on one side. it's not a lot but i wasn't sure if this would cause me issues. ive decided to be extra careful after seeing the video of the 1,300hp mercury. pictures down below if that helps
If it were me, I'd remove that flare and redo it. Since it's offset, when you put the flare nut over it, it will move off-center and it'll likely leak or give you problems down the road.
If you have a 1/2" fluted countersink drill bit, those are great for cleaning/prepping the end to be flared. It'll remove any inside material when you cut the line.
Edit: Some photos. The chamfered edge gives the flare tool a nice centered hole to go into. Keeps everything straight and tidy
My OCD goes haywire with brake lines because my cars carry my family. I don't take any chances.
AND blow them out with compressed air to remove the metal debris..
I like using NiCop can't go wrong
Deburring the line is critical. Even a touch with a file will work. Worn out tubing cutters make poor cuts.
File the ends flat and square. I used to use the flare clamp itself, clamp the line in not very tight and use it for a guide for the file
Absolute must when doing brakes.....
But, in all seriousness, take no chances. Do it right. Or, in this case, redo it. As others have stated, a wore tubing cutter or flare tool. Sometimes it just happens with new parts, too. All good, you'll get it.:thumbsup:
Somehow I've turned into an old guy and in that transition time, I've made a lot of double flares. With that, I've seen it all! The offset problem, uneven flares, lopsided ends that don't sit level in the flare nut... the list goes on. A couple of years ago I saw the Eastwood flare kit and thought... what the Hell! I pulled the trigger and spent the money. After receiving it and going through the usual learning curve, I have to say, it was worth every penny!! Beautiful flares every time!
Just my two cents....
