blackace
The KING of flats
I'm setting up my rear for disk brakes using the Scarebird adapter. I was wondering if I should use two gaskets or one. The Scarebird adapter bolts on the axle housing flange where axle flange would go. Then the axle flange goes on top of the adapter. I was thinking of putting one between the each of them like a sandwich, between the housing and adapter and the axle flange and adapter. Does it matter or just sealing with one gasket between the housing flange and adapter fine.
