To brittle means over hardened. I have Blair & I've broken them too. If HF ones are cheap enough, I'd waste a few to figure out how to anneal them.HF ones suck. Way to brittle. Once catch and they snap. I have drilled out a LOT of welds with Blair cutters..... Use a little oil and drill a pilot hole so they don't skate around and you can move fast.
https://www.amazon.com/Blair-11096-Cutter-Set/dp/B002XML5HK/?tag=fabo03-20
Sometimes a 3/8" can make it easier to make a good looking weld. 5/16 can be too small, depends on welder, and weldor. If you have spotweld timer, 5/16 probably good, you just pull trigger. 3/8 you may need to make small circle, hence more technique. Penetration to lower panel easier w/3/8"....
So is 5/16" diameter the go-to size for these HF or Blair type cutters? I'll be doing outer rockers on my 69 Charger and haven't done these types of repairs. Thx!
A pilot hole & the proper speed is the key to not burning up spot weld cutters. The "lube" needs to help keep it cool, so is technically a coolant. You're right tho, those machine shop lubes get gummy & leave residue. I've used many & some off label chems.I have no idea what brand tool I bought, but I bought my spot weld cutters off the Snap On truck and bought maybe 10 extra cutters.
Several have mentioned using cutting fluid, and while that may help with the tool life it also pollutes the area you're going to be welding in. I would never use it.
Others have mentioned about saving the first layer. If you are discarding the first layer don't waste your time drilling it's to time consuming. Just use a belt sander, you'll be glad you did.
Center punching is absolutely necessary if you intend to use a spot weld cutter. My problem with using one is I alway ended up cutting the 2nd layers as well.
As with most projects of this nature there are several ways to do it, but trust me the sanding belt can save you hours and a lot of frustration.
I use a cheap variable speed electric unit I bought off Amazon for $36 and now they are $29 https://www.amazon.com/dp/B072Q2FTLY?tag=fabo03-20
Just make sure to buy 3M Cubitron belts, as the cheap ones do not, and will not last long.
Tom
A friend used bacon grease with his blair cutters. Worked pretty good!
Thank you! I'll likely start w/ 3/8" and if those don't work, I'll try a 5/16". Appreciate your response!Sometimes a 3/8" can make it easier to make a good looking weld. 5/16 can be too small, depends on welder, and weldor. If you have spotweld timer, 5/16 probably good, you just pull trigger. 3/8 you may need to make small circle, hence more technique. Penetration to lower panel easier w/3/8".
As I wrote previous I wondered if Door Ease Stick Lubricant would work, & it would pack into cutter void like the Bacon Grease might, so no spraying. But it leaves melted grease behind to clean up.A friend used bacon grease with his blair cutters. Worked pretty good!
Made me hungry.![]()
I use bacon grease when turning certain metals on the lathe. Works well and smells loverly.A friend used bacon grease with his blair cutters. Worked pretty good!
and as a bonus you get bacon as your making the greaseI use bacon grease when turning certain metals on the lathe. Works well and smells loverly.
