Drilling LA Heads for Magnum Intake
kaharshs
Fall Creek, Oregon
I’m building a 408 stroker magnum for my Duster. I already have a nice Edelbrock intake for magnum heads, but I’m using a set of LA Speedmaster aluminum heads. Has anyone re-drilled LA heads for a magnum intake? I see quite a few posts on magnum heads re-drilled for LA pattern.
Then how would you do it? I can’t imagine staring a hole at angle. You’d have to make a jig and then???
Maybe just drill the intake for the LA head. It would be much easier.?
I haven’t decided how I plan to do it yet. I’m not an automotive engine machinist, but I have the skillset from aircraft machining to get it done. I will either make a jig for hand drilling or just put them on the mill. Either way I would likely first use an end mill to make a flat for a center drill. Then drill, tap, and helicoil. The reason I would possibly make a jig is so other people could use it or if other people wanted me to dril their heads.
This: "Either way I would likely first use an end mill to make a flat for a center drill."
That jig idea is great until someone gets it then doesn't return it, steals it. There was one available on this site until the prior situation happened.
We had a deal for doing injector cups on PS diesels. Same deal the kit cost around $300, it got sent around free of charge, some asshole gleeped it.
Only way to do it, rent it out, charge $250 plus as a fee. Fee refundable upon return of the undamaged piece.
Getting the angle right is the tough one. That's why you need a jig.
If the manifold attaching bore is perpendicular to the China wall, you could make a set of block that situate the head up on the table of the mill at the correct angle.
It would seem to one could get the angles off the engine block
Right, but it's not. That would make it easy.
Your gonna have a interesting situation to deal with concerning the bypass hose if you manage to drill the heads
Should work.
Do it the right way. That involves a roll over fixture in a milling machine and knowing the exact position and angle of the holes. If you don't have the equipment and knowledge, find someone who does or buy the correct intake manifold.
Taking a holeshooter and being a hack is no way to build an engine.
I appreciate all the responses, but my question was if anyone had drilled LA heads for a magnum intake. Was just curious if there were examples online, because I have only found examples of magnum heads drilled for an LA.
I don’t really need help on figuring out how to drill them properly as I am a experienced machinist and fabricator with access to a full machine shop. If you’re tripping on me drilling the heads, please stay tuned for a compete heart attack if I show you pictures of the cylinders I clearanced for the stroker crank. Also, I have a cheap dual pattern intake and tons of parts lying around my shop if I really needed to pivot to bolt on solutions. I was evening thinking about making my own tapered shims to fixed the valve train alignment.
