Driveshaft length question
Suspension, Steering and Chassis
  1. BUCKEYE FAN
    BUCKEYE FAN Well-Known Member
    113
    8
    Dec 2, 2014
    Akron, Ohio
    Local Time:
    3:30 PM
    I’m looking for someone who has the same setup to give me a measurement of their drive shaft. When measuring does the car need to be on the ground? Asking because it’s hard to crawl under if not jacked up on stands.
    1969 Dart custom
    Small block
    904 Transmission
    8 3/4 in stock position
    Thanks
  2. Slantsix64
    Slantsix64 Well-Known Member
    2,469
    921
    May 11, 2014
    SGV
    Local Time:
    2:30 PM
    The way i measured was from the metal end on the transmisson tail shaft (not the rubber seal area) you measure out to the rearend pumpkin yoke flange flat end. This is how the drive-line shop had me measure. Also i was a cheap ass the shop told me i needed a new front U-JOINT but i was like ehh sounds like bullshit..... Now i have been have a Slighht Vibration at 45000 RPMs lol wish i would of payed the extra 10 bucks lol
  3. Car Nut
    Car Nut Mopar Master
    14,549
    62808
    Dec 28, 2018
    Zombieland
    Local Time:
    1:30 PM
    Build some wheel cribbing.
  4. famous bob
    famous bob mopar misfit FABO Gold Member
    16,672
    6429
    Aug 14, 2011
    okla
    Local Time:
    2:30 PM
    cente to center of the u joints , weight on the tires .
    U could jack it up and block up all the wheels the same heigth to get under it .
    • Like Like x 1
    • BUCKEYE FAN
      113
      8
      Dec 2, 2014
      Akron, Ohio
      Local Time:
      3:30 PM
      Thanks guys
    • 70aarcuda
      70aarcuda Master Hoader of SBM FABO Gold Member
      15,479
      3976
      Jan 16, 2005
      las vegas
      Local Time:
      12:30 PM
      48.875 inches
    • BUCKEYE FAN
      113
      8
      Dec 2, 2014
      Akron, Ohio
      Local Time:
      3:30 PM
      Here’s my question, the DS fits and goes in, however I’m not sure I have enough room between the rubber boot and the yoke. Any ideas or opinions of this looks normal?
    • famous bob
      16,672
      6429
      Aug 14, 2011
      okla
      Local Time:
      2:30 PM
      Dang , I forgot , shove the yoke all the way in , take ur measurement and subtract 1''. Every drivesahft company I have used (3) said to do it that way --------sorry.
    • RogerRamRod
      RogerRamRod The Older I Get, The Faster I Was
      918
      518
      Jul 5, 2011
      Chesapeake VA
      Local Time:
      2:30 PM
      Slantsix64, Damn, you slant guys wind the piss outa those things, V8 guys only go up to about 7000.
      “Now i have been have a Slighht Vibration at 45000 RPMs “
      I don’t know how to put one of those Jabby things on the post from my phone
    • yellow rose
      yellow rose Doctor of Thinkology.
      22,291
      18315
      Jun 19, 2015
      Living on the razors edge
      Local Time:
      12:30 PM
      That should be fine. I don’t use that long seal any more. You only need 3/4 inch of movement on the slip joint, unless you are going to motocross your car! The more spline engagement the better off you are. Until the slip yoke bottoms on the output shaft.
    • BUCKEYE FAN
      113
      8
      Dec 2, 2014
      Akron, Ohio
      Local Time:
      3:30 PM
      Okay. This is all new to me. The guy that rebuilt my transmission put that on. At first I thought I may need to have the DS cut. I think I may have enough room with that seal, I didn’t realize there was room between that seal and the rear of the transmission. Thanks!
    • Car Nut
      14,549
      62808
      Dec 28, 2018
      Zombieland
      Local Time:
      1:30 PM
    • BUCKEYE FAN
      113
      8
      Dec 2, 2014
      Akron, Ohio
      Local Time:
      3:30 PM
      Thanks
