highflyer
as bad as droopy drawers...hinges a little sloppy and door hits pin as door is being closed...is there any way to adjust the door at its hinges or is pin rep/rep the only...tx...j
Pin and bushing, check O'reillys, napa. It can get aggravating. On a 69, we had to buy 2 kits. The original pin wouldn't work with the bushing. Bought another and got po'd. (one kit was bought on-line).
So we took all, found a pin and bushing that were tight, drilled out the hinge, cut down the head of the bushing, then it all worked.
