drum brake spindles
DennisP
New Member
Manassas Va
Rating - 0%
0   0   0
Good evening,
I am in the market for 73-76 drum brake spindles and Large ball joint upper control arms. I am in the Washington DC area.
Zip is 20111.
Would like to get them in the area if possible because shipping is going to be $$$$$$$.
Thank you,
Dennis P
I think you'd get more response if your ad made sense. All a-body front drum cars used the small upper ball joint. Many b-body cars used front drums with the larger upper balljoint but these were made up to around '72. Are you sure your ad is correct?
Hi Valiantpatrol,
I was under the impression that the a body cars from 73 on were large ball joint cars due to the parts standardization that happened.
I am looking for the 10 inch drum spindles so I can do the Viper caliper set up by AR Engineering.
Thanks for asking for clarification.
Dennis P
Hello Ed And Rocket,
Thanks for your info.I got a PM first from another member and am looking at that.
Thanks again,
Dennis P
