Drum brake ??
damon77
New Member
whittier
I got a 67 dart slat six drum all the way around non power. i want to know if i buy a power brake booster will it both right up or do i need to do more to it?? thank.
On my 74 when I did it, the push rod was different length and the power master cylinder was different too.
You'll need the whole power brake setup......booster, brackets, linkage, braces, etc. As 74desertduster mentioned, you may want to replace the master cyl. with one for a power system. You can try it first but usually they're too sensitive.....you just breath on the pedal and the brakes lock up. Some people like it that way but not me.
