I was mocking up the driver side manifold on my new EQ heads and noticed the bottom of the ports are not sealing because the port in the manifold is lower than the machined pad on the EQ heads. has anyone else run into this and if so how did you get them to seal ? Weld up the bottom od the manifold? I would have to build up the floor of the manifold then machine it flat? This is for a dirt track car so noise isn't an issue but worried about the leak causing a burnt valve or a fire LOL..
