The ptfe braided stuff, looks aside, is incredibly easy to use. Cutting the line and attaching a fitting takes a minute or two tops.
The push together stuff, I think that's what it's called, is a nightmare.
Like this - without the tap.
Those Summit chrome carb fittings are nice pieces, and come in different degrees, these are the 45s.
I'll take your word for that and avoid them.Not on the new ones it doesn't. Have you seen the newer generation from Holley? They are the thinnest, crappiest cheapest things you've ever seen. I had to be super careful with mine when I was installing it that I didn't bend or break it. I remember the old ones were thick as could be and you could barely bend them. These new ones, it's hard not to bend them. They are also crappily soldered together. Just junk. And what makes it worse, I HATE braided line and refuse to use that crappy lookin stuff.
Last one I bought was a Mr Gasket. It was typical steel fuel line with chrome plating but nothing to write home about.
The flares weren't finished well and of course it was made you know where.
Comapre that to this used late 80s Holley non-chromed.
My suggestion for the OP was not to have a any soft line between the two bowls. Not braided, not anything. Less chance of leaks.
