Dual Quad Intake Questions
1967DartGT
Livingston, MT
Is anybody running one of the Offenhauser dual quad intakes on their small block? What has the performance been like for your set up? What carb sizes are you running? Is there any performance difference between the low rise and high rise version? Please post any pictures of yours mounted on the engine if you run one.
Heres mine. Carbs have been dialed in but I haven't fired the engine yet.
Have used this manifold with two Holley 500 two barrells. Once dialed in the torque curve of the motor was broad and flat from 4500 to 7000 rpm. This was on a 318.
Smokin Roy??
