Duel scoop set -up
If you're trying to do something like a cold air intake by hooking the air cleaner up to the dual scoops, you'd be much better off running the inlets to the front of the car, probably somewhere behind the grille.
I love the way the dual hood scoops look, but at a couple inches off the hood they don't stick up enough to really get out of the boundary layer of air on the car, so there's no "ram air" effect to be had at all. Better to use them more like a vent to let hot air out than to try and use them as an intake.
Something like this would work a lot better...http://www.jegs.com/i/Spectre/865/7118/10002/-1?parentProductId=1841264
Or a more "home made" route like this. Not pretty, but plenty effective.
