cuda67
Please, don't beat me up too bad. I am having a slight issue that I can't get right.
I have a 1967 Barracuda. I replaced the 318 with a magnum 360 about a year and a half ago. It is a crate 360 magnum from Mopar. I used the 318 exhaust manifolds and there in lies my issue. I had to replace the Accel 8.8 wires about 10 days ago, the old ones were brittle. The problem is with #5 and 7 wire. I can't get them off the exhaust and I don't know which loom will work with the 318 exhaust manifold on the driver side. It is the exhaust and travels up before down and it leaves little to no room to move the wires. I tried the heat insulator boots but they don't help. I tried the fancy loom that attaches to the valve cover but they don't fit that driver side due to the high manifold. I am hoping that someone has used the exhaust manifolds and knows the answer. A picture or part number or anything would be appreciated. Thanks:banghead:
