Short. Need long ones for many wheel covers, but the trim ring of a rally wheel dips down into the wheel in a way that the wheel covers do not. So, short valve stems are fine.
I use steel valve stems, because the trim rings will rotate and cut into the valve stems. Lot of flex in those rally wheels. And the steelies for that matter — I used to shed wheel covers like the Charger in Bullit.
