Dumb question: Rallye wheels
jos51700
Green Bearing thread connoisseur
Bel-Ray
I found Made-in-USA valve stems on McMaster Carr.
What length is needed for Mopar Rallye wheels with trim rings?
Thanks all!
Keep it simple, two sizes of automotive tire valves to pick from.
I had short ones on mine. (Don't see these automotive type at McMacsters).
Short:
Long:
Short. Need long ones for many wheel covers, but the trim ring of a rally wheel dips down into the wheel in a way that the wheel covers do not. So, short valve stems are fine.
I use steel valve stems, because the trim rings will rotate and cut into the valve stems. Lot of flex in those rally wheels. And the steelies for that matter — I used to shed wheel covers like the Charger in Bullit.
