Because the few thousanths of lift is the take up ramp, and different grinders use different designs, I don't think you'll find that accurrate. That'swhy the published numbers don't start at zero lift. However, I am pretty sure that if you have a cam whose specs start at .004" lift, the take up ramp will have been past at that point. If you have one that starts .002 later, they used the other .002" for the ramp too.
