Duster Bucket Seats & Console
1965t5
Active Member
Milwaukee
Hi everyone - are the bucket seat frames and cushions same from 70-75 that you could use the 70-71 covers on say a 73-75 seat?
Also is the floor console same for all years too or did that change?
Seat covers absolutely not been that route. 72 up seats are a little fatter n wider than 70 71 seats. Nobody at least six months ago made seat foam for the 72 up seat frames.
so 72-75 is same on seat foam and material fitment?
70-72 has a plastic seat back. 73 and up does not. I recommend looking at upholstery sites like Legendary and see if the part #'s for the foams they sell are the same or different year to year.
1970 - early 1971 seats are on their own.
Later 1971 different than '72 & later.
But, for each model year the frames will interchange with the correct foam & upholstery.
No one reproduces 1972 up foam yet, so you will need donor frames with the correct foam for your application if you want an OE look.
There are also seat medallions to consider since they are not reproduced either.
A -B - E seat tracks will all fit the seat frames, but the floors are different so they will not all interchange.
