duster dash cluster question
Atlanta, Tx
Hey does anyone kno if the 73 dusters had the option for a rallye dash? And if so does anyone have one they wanna sell? Not too concerned on condition
71 was the last year for the rallye dash in the A-Body cars....
Thanks. Yu could probably put a rallye dash in a 73 though correct? Shouldn't it go in like tha standard dash?
You'd have to modify the metal dash frame....Also, would need a rallye dash harness.
A lot of work, but it can be done. Try searching the "Body, Interior & Trim" forum for related threads....
If you can find the metal frame, cluster and wiring harness that would be the easiest way
You need to know that no pre 73 climate controller will fit a rally dash or operate the 73 and up plenum.
You can modified a 67-72 box to fit the 73 up fire wall.
