smartken22
U.S. Navy Senior Chief
OK, here is the latest dilema! I am in the process of rebuilding the front end of the car. I currently have the K-member removed and was in the process of replacing all of the bad components when I realized it would be cheaper to just do a disc brake conversion considering all the parts that are bad. I also ordered new lower ball joint that happen to be for a disc brake setup vice a drum so I either need to sell them or try to return them. I have been researching which brake kit to go with and found an awesome deal on Ebay for a front kit by "Right Stuff". It has everything I need however I noticed a couple of issues I am going to run in to.
1) Bolt pattern for the kit is 5x4.5...my current setup of 5x4. Now my rims and tires are shot anyway and I plan to go with Cragar SS rims but do not know which bolt pattern to go with.
2) Sway bar is going to get replaced...am I going to have clearance issues with a new sway bar? I was looking at the Hotchkis setup, but I may have to go with firm feels sway setup in order for the calipers to clear.
Any advice would help me out. I hate to spend all this money to find out stuff does not fit/work. Thanks in advance.
