DUSTER door emblem
DUSTPAN340
Cedar Rapids ,IA
As some may know..I'm redoing the DUSTPAN340 a tad....what I have now is two different plastic door emblems with Duster on them...one has Duster in white and no trim color around the emblem..the other has gray or silver around DUSTER and the two lines around the leading edge (boarder) of emblem...can anyone tell me the true way the door emblem should look...and if you have pictures...
thanks
wayne
here are mine-the driver one is actually a '71 I put on because it was in better shape than the original:
and the original '72:
they're both all-black except the silver (at least I'd call it silver) inside the 'Duster' lettering- the '71 is actually 1/16th of an inch shorter (1 1/4 vs. 1 5/16 for the newer one) as the '72 one has a wider section outside the outermost raised line...
edit- and, yes, I still have some paintwork to do in the interior of my car :D
Thanks for your pics...this is what mine look like now from my 1970...will do mine like yours...maybe the previous owner painted the trim and outline around duster him self...thanks again..
wayne
that looks like it could be correct, too- mine could all be worn off- I can't say for sure (although they're from different cars...)
You never know...just wish I knew what color to put on mine...or should I take paint off and be all black like yours...thanks....
wayne
wayne
just wanted to mention- I was looking at the resto thread started by 'orangetwist' and it looks like his are just like that, with the white/silver around the outside...
