Duster Headers !!!!!!!!
DusterforLife
New Member
Hernando Ms.
Need a set of Headers for the 74 Duster............. What Headers can I buy with NO modification ?????? It has Power Steering....Do I need Shortys or can I use the Standard Kind ???
TTI step headers, easy to install and clears power steering. Or dougs but I dont have any experience of them.
TTI with out PS and the are the olny under rail headers all other are fender well style as best I know. I used them tight but fit
Mine hang low on both sides really, but more on the drivers side. I had 205/70/14s on the front and I'm going to 225/60/15s and will probably pull the torsion bars up some because it was a bit droopy in the front, and needs a complete alignment now anyway. I used to have only 2.5-3" but I think I'll end up with more like 5" with the new setup. Also going to a 73 style spool motor mount K frame witch looks like it pulled it up 1/2" compared to the aged 68 style setup.
