you can do like I did years ago I traced the tab from one car on cardboard, then transfered it to steel plate, cut it out then heat to bend up to make it into a u shape, then just weld the tabe to the lower control arm, if you have a RH or LH after you make a template just invert to get the opposite side, with a little fitting and a good Mig welder it will look better than stock. Hope this helps
Larry
