twister360
Installed new 5 leaf rear springs and new KYB shocks on all 4 corners. Adjusted torsion bars per the manual and the right rear sits 1" higher. I did this 3 weeks ago so I figured the suspension would have settled in but rear still uneven. I measured the front from the floor to bottom of wheel lip ( tape centered in the middle of the hub cap ) and both fronts measured 25 1/4". Left rear was 25 3/4" and right was 26 3/4". 235R70X15 all around and 28# in tires and on flat surface, 1/2 tank of gas and spare in trunk. Is this normal? Any way to balance car on all 4 corners?
Thanks. Gary
Thanks. Gary
