1. dICKj
    dICKj Well-Known Member
    84
    64
    Sep 25, 2018
    Kilgore, TX
    Local Time:
    5:26 AM
    Can I tow my 1974 Duster with 908 auto trans behind my motorhome, or will the driveshaft have to be removed?
    DickJ
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    21,388
    9631
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    6:26 AM
    You need to remove the driveshaft. I assume you mean 904 automatic.
  3. Princess Valiant
    Princess Valiant Duster specialist FABO Gold Member
    24,584
    18576
    Dec 14, 2011
    Colorado
    Local Time:
    4:26 AM
    Remove the driveshaft and use an extra slip yoke bail wired to the tailhousing to seal the trans.
    • Agree Agree x 2
    • Scody21
      Scody21 Just send it
      788
      739
      Jul 17, 2019
      Southwest Washington Coast
      Local Time:
      3:26 AM
      It’s best to drop the drive line and get a cap or old slip yolk and safety wire/ zip tie it to the tail housing so ya don’t dump all the fluid out...
    • crewchief
      crewchief A & P Mechanic FABO Gold Member
      562
      266
      Jan 17, 2014
      Malta NY
      Local Time:
      6:26 AM
      If you flat tow it (which is not recommended), you will have to remove the drive shaft. Why don't you trailer it?
    • tonysrt
      tonysrt FABO Gold Member FABO Gold Member
      970
      504
      Dec 25, 2016
      Northport, NY
      Local Time:
      6:26 AM
      I hope you meant a 904 tranny. Remove the driveshaft. I know that's not you wanted to hear. Unless you can keep rear wheels off the ground, remove the shaft.
    • Dana67Dart
      Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
      7,462
      5102
      Jul 16, 2017
      Northern Colorado
      Local Time:
      4:26 AM
      Flat tow remove the rear U joint from the diff. ( 4 bolts)
      Tape up the U joint, so the caps don't fall off.
      Bag the 4 bolts and 2 caps and put in the glove box (don't want to leave them at home in the garage.
      Leave the front yoke in the transmission.
      SECURELY tie the drive shaft up under the car being sure it can't slide backwards.
      Tow away.
      If you need to reinstall on the road put one side of the car up on a curb that will give you about enough room to wiggle under and reattach the 4 bolts and 2 straps on the rear U joint.
    • SGBARRACUDA
      21,388
      9631
      Dec 7, 2006
      Local Time:
      6:26 AM
      Why not buy a tow dolly and put the car on backwards? Hell with crawling under the car over and over.
      • Agree Agree x 1
      • Dana67Dart
        7,462
        5102
        Jul 16, 2017
        Northern Colorado
        Local Time:
        4:26 AM
        Towing backwards is frowned apon, engine mass, steering linkage etc. Sure it could be done but I suspect OP is looking to tow long distance "behind motorhome"
        Not sure this would be any better but...
        Put front on tow dolly rears on dolly wheels below.
        For the price might as well get a trailer
        • Agree Agree x 2
        • SGBARRACUDA
          21,388
          9631
          Dec 7, 2006
          Local Time:
          6:26 AM
          All I can say is long before I could afford a car trailer I bought a beat up used Dolley. I towed a many of cars backwards. Longest was from Roanoke Va. to Plant City Fl.
          • Like Like x 1
          • dadsbee
            dadsbee FABO Gold Member FABO Gold Member
            1,089
            2428
            Nov 25, 2020
            Penetang, Ontario
            Local Time:
            6:26 AM
            Towed my '90 TBird SC coast to coast and then some behind our 34' Motorhome without a single issue backwards on a dolly... well other than parking lots that were too narrow to do a 180 in !
            • Like Like x 1
            • SGBARRACUDA
              21,388
              9631
              Dec 7, 2006
              Local Time:
              6:26 AM
              If your rear towing a lockable column it is no big deal towing backwards. Now towing a pre 70 means you have to tie the steering wheel off in the straight position.
              • Agree Agree x 2
              • Dana67Dart
                7,462
                5102
                Jul 16, 2017
                Northern Colorado
                Local Time:
                4:26 AM
                Not sure I like the exicution of this but the idea is fairly solid
                Coupling
                • Like Like x 1
                • SGBARRACUDA
                  21,388
                  9631
                  Dec 7, 2006
                  Local Time:
                  6:26 AM
                  I've heard of this before but never knew anyone that has used it.
                • dadsbee
                  1,089
                  2428
                  Nov 25, 2020
                  Penetang, Ontario
                  Local Time:
                  6:26 AM
                  They're an absolute PITA to get working properly. Did that to the wife's sportrac so we could flat tow it and I spent more time under the truck fidling with the thing that dropping the shaft would have been easier. The unit is also made of cheap quickly rusting steel.
                • 33IMP
                  33IMP Well-Known Member
                  1,651
                  1735
                  Jul 3, 2020
                  Taxifornia, soon 2b arizona
                  Local Time:
                  3:26 AM
                  This is what we used, back in the good old/bad old days. The tow hubs were made from amc hubs welded to 1/2" steel plate with the bolt pattern drilled in.
                  • Like Like x 1
                  • 67Dart273
                    67Dart273 FABO Gold Member FABO Gold Member
                    50,825
                    19510
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    3:26 AM
                    ^^Haven't heard "tow hubs" in a long time!!! Friend of mine used to use them on a Jeep
                    On a side note the earliest WWII Willys had same hubs front and rear---the rear used floating axles similar to a 3/4T The fronts of course had the drive caps on, and is what you removed to bolt on "locking hubs" when they came out. So on the War II jeeps you could pull the rear axles and cap them off.
                  • Demonracer
                    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                    5,201
                    3234
                    Jan 31, 2010
                    Cleveland, Texas
                    Local Time:
                    5:26 AM
                    33IMP, I had a setup like you pictured for many years & flat towed many cars that way. At 2 day races, we slept in tents & if it rained, we slept in the seats. AH, the good old days. LMAO
                  • 33IMP
                    1,651
                    1735
                    Jul 3, 2020
                    Local Time:
                    3:26 AM
                    We used that setup to flat tow to riverside raceway before it closed in the eighties, and bakersfield for the firestone/centerline finals (havent used that description in a few years, lol). Used an ez-up and pool mattresses in the pickup bed.
                    Funny thing, it would work just as well today, and be easier to set up. A light battery impact and an aluminum floorjack would be easier than our old 80 lb floor jack and star wrench. That star wrench got turned a bit, what with 3"studs on the race car... kinda miss old days, and being that young....
                  • mcodecuda
                    mcodecuda Senior Member
                    767
                    328
                    Sep 17, 2007
                    Sherrills Ford NC
                    Local Time:
                    6:26 AM
                    Scares the hell out of me. IMO those tires wouldn’t last long going down the road at highway speeds. Tow trucks could get away with it because they went short distances at reduced speeds.
                  • Scody21
                    788
                    739
                    Jul 17, 2019
                    Local Time:
                    3:26 AM
                    I agree.
                    I’d rent a car trailer from U-haul...
                  • 67Dart273
                    50,825
                    19510
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    3:26 AM
                    Towing backwards, depending on front end alignment, "could be scary."
                    On a side note, darn few STICK SHIFT vehicles can be towed safely without disconnecting the drive shaft as well. Don't let anybody tell you different.
                    • Agree Agree x 2
