dynamic effective compression ratio?
moturbopar
mesa az
My effective compression ratio comes out to 7.8, Do you guys think this will be OK with 93 octane? Its a La open chamber head (no quench). What can these engines get away with on 93?
Thanks
..............U could run 87 or 89 with that low of a #................kim.............
I was getting worried from what I was reading. My mechanical is 9.6 to 1 but i guess the cam bleeds off enough cylinder pressure. hopefully it will let me get away with retarding the timing less, when Im spraying it.
Thanks
