Map63Vette
Has anyone ever tried an E body rear end swap into an A body that has pictures or numbers to share? I started measuring everything up and I'm pretty sure it could be done with the right backspacing. The E body axle is only 1.5 inches wider than a B body. I've come to the conclusion that I have an F body 8.25 in my car and I recently bought what I thought was a B body 8.75, only to find that it was actually an E body housing today. However, I already bought new bearings and had them pressed on the axles. I was looking at 7" wide rims with 5.6" of backspace, and from all the figuring I can come up with it seems like it would fit just fine. If the housing won't fit can I use the E body axles in a B body housing? I checked Moser and they listed two lengths for a B body, one was an inch longer than the other, but the E body axle was only maybe .75 inches longer than the longer B body axle.
