E85 tuning
DesertBilly
Active Member
Phoenix
Hey guys me and my dad are converting the car to e85 and would like to know about tuning it and experiences you guys have had with running e85. We already sent out one of our 750 proforms out to be modified for e85. All I know so far is that it requires more fuel and lowers engine temps and is 110 octane it the car has a 410 aluminum headed stroker that will be seeing both alot of strip use and street. I know the timing will have to be advanced and maybe a hotter t-stat and bigger jets may be required. Any help is apprecited thanks.
Joe.
if the carb is being modified for e85...they make the necessary changes to run on e85....quick fuel technology makes a kit with new meter blocks for e85....which will make the conversion alot easier if you are doing it yourself.....
you should have supplied the guy moding the carb with your engine info and where you race so it can be properly set up.
