Hmm...I'm a bit out of my depth here , but what I understand is this:
A crank is index ground to correct the distance of each of the rod journals from the axis of the crank - correct?
So I assume that by turning the journals down on a very slight offset from their current location, this moves their "center" slightly so they are all positioned at the correct distance from the central axis of the actual shaft - Im hoping this is correct?
So the .035th is the total variation of all the journals respective from the central axis. (Ie one might be 10th, another 10th and another 15th out)
What Ive been told is that they can be brought into correct alignment by taking varying amounts of between .015-.020th of each rod journal.
I guess this is where i find out if ive got the story mixed up...LOL!
