There's one big disadvantage to grounding it. It's a safety item. My Cuda was grounded out when I bought the car and they didn't tell me and one day I was installing a stereo in it and had to pull the shifter down in low to access the under dash good. Wife called me to dinner when I was finishing it up and I forgot to put it back up in park and a few days later I started it up when it was dark in the garage and dome light didn't work so I didn't notice it was still in gear. Dang near ran into my work bench before I got it stopped. For that reason I never bypass them. There's one other way you can fix it pretty cheap. Use a newer style switch. Their only about $10-15 at the auto supply. They have 3 pins. The center pin is the neutral safety pin so you just run your wire to it and your set.
