Its 4140 steel about 1/4 inch thick & heat treated from them. Not spring steel at all. I placed a tube that fit the I.d. of the bar in 1st about 3inches long. Then made a wide v-grove in both sections of tje roll bar. 1 root pass & 2 cover pass's. No problom at all. Not to mention its double the size of a factory sway bar to begin with. I didn't want to do it, but was really tired of back & forth with aftermarket companies! Ha, ive got another story about SSBC disc brake kit A153 ill share in the brake section. Will NEVER recommend them what so ever!
