[WANTED] Early "A" Body Vent Wing Bolts
coalman
Texas
Do any of you have a couple of Vent Wing Allen Head Cap Bolts laying around for the Vent Frame adjustment? Page 621 Fig. 62 of the shop manual. Thanks a lot.
Have a pic of them might have them on 66 cuda doors if that would work.
66 DVERT has a post in the early "A" Body forum with a picture. I think I can get a couple of the bolts at a good hardware store, the spacers not. Thanks for reply
Here is a picture of the installation..
Yes, the bolts are just plain old 1/4-20 Allen socket head cap screws. The plate can be made from a pice of sheet metal. Just space some 9/32 holes to match the holes in the vent window frame.
Yes, the bolts are just plain old 1/4-20 Allen socket head cap screws. The plate can be made from a pice of sheet metal. Just space some 9/32 holes to match the holes in the vent window frame.View attachment 1715367577
Thanks.. By the way you don't happen to know the dimensions of the plate, I think it is a rectangle..
I don't have one out at the moment and the weatherstip is glued over my access holes so I can't help with that. Sorry.
there is a little flat plat that is slotted that slides down in there also if you don't find the screws or the plates let me know
The screws I can get at a hardware store, the plates are a problem all four are missing. I might be able to make them out of fender washers, if I know the size. Thanks for your time and help!
there is one flat plate per door they are in the slot where the allen screws go into the plate then into the wing window
My door has two rectangular openings per door where the bolts go in with nothing in between. Thanks
take a pic and dig in those holes and see if the flat plate is still in there
I can take a picture tomorrow, really not necessary, there is nothing there. The bolt I have was just started in window assy. threads, it would not hold anything. The plate I am thinking should sit on top of the rectangular openings in the door to allow adjustment of the vent window. Is this correct? Thanks again...
theres a little slot it slides into then the allen heads come in from diffrent square openings see if the service manual shows it?
I went to the hardware store, got a couple of cap bolts and washers. Ground the washers down so they would fit inside the openings and got it to work. Thanks for all your input...
