Have a pic of them might have them on 66 cuda doors if that would work.
Yes, the bolts are just plain old 1/4-20 Allen socket head cap screws. The plate can be made from a pice of sheet metal. Just space some 9/32 holes to match the holes in the vent window frame.View attachment 1715367577
I don't have one out at the moment and the weatherstip is glued over my access holes so I can't help with that. Sorry.
there is a little flat plat that is slotted that slides down in there also if you don't find the screws or the plates let me know
there is one flat plate per door they are in the slot where the allen screws go into the plate then into the wing windowThe screws I can get at a hardware store, the plates are a problem all four are missing. I might be able to make them out of fender washers, if I know the size. Thanks for your time and help!
take a pic and dig in those holes and see if the flat plate is still in thereMy door has two rectangular openings per door where the bolts go in with nothing in between. Thanks
theres a little slot it slides into then the allen heads come in from diffrent square openings see if the service manual shows it?I can take a picture tomorrow, really not necessary, there is nothing there. The bolt I have was just started in window assy. threads, it would not hold anything. The plate I am thinking should sit on top of the rectangular openings in the door to allow adjustment of the vent window. Is this correct? Thanks again...
